Dear All,
Is it possible somehow to use this sensor for IOT purposes?
CY8CKIT-022 CapSense® Liquid Level Sensing Shield
https://www.cypress.com/documentation/development-kitsboards/cy8ckit-022-capsense-liquid-level-sensi...
I have the CapSense shield and PSoC4 development kit.
I like to send the liquid measurement data from multiple liquid storages equiped with CapSense and PSoC4 into a central computer.
Do you have any recommendation for this? Is using Raspberry Pis together with the Capsense and PSoC4 devices can be a solution?
Thank you in advance and look forward to your feedback,
Gabor
ispn:39601:1:0
l1:314:1:0
Hi GaFe_4682661,
If you are looking for a WiFi solution with CapSense, we recommend you to use PSoC 6 WiFi BT pioneer kit.
You can use PSoC 6 to interface with the CY8CKIT-022 CapSense® Liquid Level Sensing Shield and the on-board Murata LBEE5KL1DX Module (CYW4343W WiFi + BT Combo Chip) for WiFi connectivity.
We recommend using Modus Toolbox software for development.
If you want to continue with PSoC 4 for CapSense, you can use the PSoC 4 chip and integrate it with any WiFi module (such as Raspberry Pi) as a solution.
Bragadeesh
Bragadeesh
Hi gafe_4682661,
Could you please let us know if you are looking for a BLE/ BT/ WiFi connectivity? We might be able to suggest you the best solution based on your requirement.
Bragadeesh
Bragadeesh
I am mainly looking for a solution with WiFi connectivity.
Thank you in advance,
Gabor
Hi GaFe_4682661,
Bragadeesh
Bragadeesh
