PSoC 4
DeCo_1926091
Contributor
Where can I find a reference document for the C language and libraries used with psoc creator to program PSoC4 ble?
Dennis
MotooTanaka
Esteemed Contributor
Dear Dennis-san,
If you are using the default C compiler of PSoC Creator,
you can access the documents from Menu
  Help > Documentation > GCC Documentation
And API for each components can be referenced via the components' datasheet
which can be accessed
(1) From component catalog > component symbol > datasheet
(2) From the configuration dialog of the component
5-Mar-2020
Motoo Tanaka
MotooTanaka
Dear Dennis-san,
5-Mar-2020
Motoo Tanaka
