PSoC 4
Hi all,
I am using CY8CKIT-042-BLE-A kit.
I am trying to use OTA FIXED STACK bootloader in custom profile BLE project
I am getting  these errors
Build error: CY_BOOT: Section .cy_checksum_exclude size exceedes specified limit.
Build error: section .cyloadablemeta loaded at [0003ffc0,0003ffff] overlaps section .cy_checksum_exclude loaded at [0003fe00,000400ff]
Build error: The command 'arm-none-eabi-gcc.exe' failed with exit code '1'.
I am not getting how to slove this.Please help me to resolve this issue.
himam_31
Did you have a look at the section "8.4.2 Using Checksum Exclusion" in "AN97060 PSoC® 4 BLE and PRoC™ BLE – Over-the-Air (OTA) Device Firmware Upgrade (DFU) Guide".
Hima
himam_31
Hima
Hi Hima,
I have a similar build error for my CYBL11172-56LQXI for BLE.  I get this error :
Build error: section i.smp_handle_secure_connection_only_mode loaded at [00023400,0002342b] overlaps section .cy_checksum_exclude loaded at [00023400,000236ff]
Can you provide a sample project, that would be a great help!
FYI: I am using No security for BLE on the security mode for now.
Dharav
