I was using a CY8C4248QI-BL-483 which is EOL. I am switching to a CY8C4248QI-BL-583.
The basis for our application is the BLE_OTA_FixedStack_Bootloader/BLE_OTA_FixedStack_Bootloadable sample.
For the bootloader portion on the new chip, I rebuilt it using the 583 variant.
PSOC Creator insisted on changing the bootloadable to 583 as well.
I can load the bootloader and the newly built bootloadable with success.
But we have many units in the field that are using the 483 chip.
Is there a way to allow the bootloader to load the bootloadable portion from either build?
Or load the 483 bootloader on the 583 chip?
I can then continue to build the 483 version so that the installed base and the new chip can be updated.
Karl
PSoC 4 MCU
- ble
- bootloader
Hello.
You might want to read this thread:
Solved: Can a single Bootloadable firmware be used in OTA ... - Cypress Developer Community
Hello.
