PSoC™ 4
ChNi_2249236
New Contributor II
Hey Guys & Gals,
I'm trying to set up the Over-The-Air BLE Firmware Upgrade and I'm getting the error: The row number exceeds the bounds whenever I try to upload the cyacd file. The cyacd file was created using a bootloadable component. Any ideas what's going on here guys?
Thanks in advance!
ChNi_2249236
New Contributor II
The fixed stack I was using eventually worked. I forgot to run the mk.bat file. I am now using the OTA External memory now and theres no need for the BLE Dongle. Thank you!
rola_264706
Honored Contributor II
Could be a program issue or you are trying to put to large a program in to the device.  Please post your code so we can check it.
ChNi_2249236
New Contributor II
I'm using the example for the Fixed OTA BLE alongside the Cypress BLE App. I'm just trying to verify if I can send a firmware update before building my own program, I'm sending over the bootloadable that's contained in the application
rola_264706
I have tried that example and it works as it should. Did you follow the PDF that came with the example.
rola_264706
What version of PSoc Creator are you using?  Have you updated the Dongle to 4.2?
ChNi_2249236
New Contributor II
