PSoC 4
DeTo_1826166
New Contributor II
We are really interested by the soon incoming bluetooth mesh (based on SIG specifications), that could fit well with home automation with best range plus mesh.
Can we know when Cypress will release a 5.0 stack and next a mesh stack ?
Are the actual 4.2 Cypress chips compatible with the Bluetooth 5.0 ? (it should apparently i but didn't see evidences of it)
Thank you for your answers.
Mesh Specification will be supported on CYW20719 chip. But this chip follows BLE 4.2 specification only. The mesh specification is in the developmental stage and might take some months for release. Our only chip which follows BLE 5.0 is PSoC 6 BLE. But mesh specification is so far not implemented in it.
- Madhu Sudhan
- Madhu Sudhan
pekac_2226911
New Contributor
Hi Madhu,
Any update when psoc6 will have the mesh support?
Thank you for answer!
