PSoC 4
bewac_2776061
New Contributor II
I'm working currently with the BLE module and ADC, and want to scan 6 sensors (voltage as input signal (uint16)), so i defined in ADC-SAR 6 channels.
Could someone tell me, how can i get the converted values from ADC (which function to be used) and send to receiver (i just defined the Server Character "Read" and "Notify" in GATT Profile), and "Server UUID" in GAP advertisement packet
Are there any examples dealing with the same problem?
Thanks!
Owen_Zhang123
You may refer to the BLE Temperature Measurement in the code example of creator.
MichaelF_56
Which BLE module?
bewac_2776061
New Contributor II
It is CY8CKIT-042-BLE-A with CY8C4248LQI-BL583 on board.
MichaelF_56
Thanks.  Moving this to the PSoC 4 BLE forum so someone from that apps team can respond.
Owen_Zhang123
