PSoC 4
The cypress Proc4 BLE gives direct advertising report event, even when the direct address from the advertising device is not resolvable private address (Section 7.7.65.11, BLUETOOTH SPECIFICATION Version 4.2 [Vol 2, Part E]).
In detail:
I am using the CY5676A PRoC module in HCI mode, with the latest Bluetooth component(v3.10). The UART pins on the module receive/send the commands/events from/to a computer using script.
The advertising device has non-zero IRK and the scanning device has zero IRK, and the advertiser is set for direct advertising high duty cycle. The peer device is set for scanning with filter policy 2 or 3. What the script expects is a advertising report, while what the scanning device generates is a direct advertising report.
Anyone faced the same issue? Is there already a bug fix on this?
Kiran
we are working on this on the Tech Support Case you created.
Thank you.
- Madhu Sudhan
