I am a beginner using PSoC 4200L pioneer kit. I want to take in audio through the micro-usb and analyze it for amplitude extraction. Where would I begin? After googling, it seems that most designs take USBFS data into DMA, but I'm not sure.
Any links or projects would be helpful.
Thank you.
- audio
- psoc 4200l
- usbfs
You can refer to the code example: CY8CKIT_046 USB Audio.
For information on USB Audio you can refer to the link: https://www.electronicdesign.com/embedded/achieving-bit-perfect-usb-audio
I have attached the pdf of the above article below.
Best Regards
Ekta
Best Regards
Ekta
