Hi
We use CY8C4245PVI-482 in one of our product lines and having trouble obtaining more due tot he current shortages. Can someone recommend an alternate 4200xx part that may still be available in stock somewhere. We have enough for next 3 months or so and need to have more by the time they run out.
We use the SSOP-28 package but can redo the board to accommodate QFN or TQFP.
The requirements are not stringent. It needs 18 x Digital IO and a single 8 bit or higher resolution ADC or OP amp comparator would be ok instead. RAM and ROM are not critical, the code is small and just handling IO states in real time without need for large buffers. 48MHz is good but again, we can run at lower speed if required.
PSoC 4 MCU
Hi @down_under,
You may check the below parts:
PSoC 4200 family:
CY8C4245LQI-483
CY8C4245AZI-473
PSoC 4200L family
CY8C4247AZI-L423
CY8C4246AZI-L433
PSoC 4200M family
CY8C4246AZI-M443
CY8C4246AZI-M445
You may check other parts mentioned in the "ordering information" section of the family datasheets:
1. PSoC 4200 family datasheet: https://www.cypress.com/file/138656/download
2. PSoC 4200L family datasheet: https://www.cypress.com/file/222206/download
3. PSoC 4200M family datasheet: https://www.cypress.com/file/377971/download
You may contact the sales office for more information - https://www.cypress.com/about-us/sales-offices
Nikhil
Hi @down_under,
PSoC 4200 family:
CY8C4245LQI-483
CY8C4245AZI-473
PSoC 4200L family
CY8C4247AZI-L423
CY8C4246AZI-L433
PSoC 4200M family
CY8C4246AZI-M443
CY8C4246AZI-M445
Nikhil
I cannot find any distributors with these available online and listed lead times are around 47 weeks
Hi @down_under,
The sales office will be in a better position to guide you regarding distributors and lead time information. You may contact the sales office here - https://www.cypress.com/about-us/sales-offices
Nikhil
