PSoC 4
I want to buy your BLE evaluation kit, but would like to make sure I can use it for my custom application first. I want to use the kit to transmit non-connectable advertisement packets. I want to have control on the timing gap between packets at a given advertising event. Is that possible with your BLE stack ? My goal is to go as low as 50usec beween packets in one event.
Thansk
Iirc, the advertisement minimum timing is roughly 7-20 ms
himam_31
It is possible to send non connectable advertisement packets.We are not clear about the second requirement can you elaborate.Do you want to control the time between each advertisement packet?
Hima
50 us timing between advertisement packets might be hard to achieve on the kit from what I've seen; Others might know better though
AnCo_2736831
Contributor
I think that this may be a similar problem that I am having. The advertisement timing is out of control.
