PSoC 4
Hi
I have a project related to Adaptive Frequency Hopping (AFH). I am in basic level with the hardware and I do not know if I can have access to the
AFH pattern and update it in SYPRESS devices. I have tried nordic and TI devices but unfortunately I could not find my answer with those hardware.
Ali
AnjanaM_61
Hi Ali,
We don't have an option to find good / bad channels. You may have to do it in your application side.
We do have direct API to select particular data channels for the BLE communication.
CyBle_GapcSetHostChannelClassification() is the API for the same. Please go through the API description in the BLE component datasheet for details.
Anjana
Can you please explain more about your requirement? Are you trying to decode a AFH pattern?
-Madhu Sudhan
Hi Madhu Sudhan
Thank you for the reply. That is right I want to decode and use my own pattern. I want to change the blacklisting channel pattern. Identifying good and bad channels based on different method. For example, in BER based blacklisting I want to change the % of BER to identify the channel as a bad channel for the next scan.
Ali
AnjanaM_61
Hi Ali,
Anjana
