PSoC 4
JuIn_1625121
Valued Contributor II
About MBR3, when are Capsense Parameters calculated in SmartSense?
About PSoC, timings of calculation is described below table
at "PSoC® 4 and PSoC 6 MCU CapSense® Design Guide".
The customer wants similar imformation.
Inoue
BragadeeshV
Hello Junichi,
MBR3 and PSoC 4 uses the same algorithm for Smart Sense and hence this data applies to MBR3 also.
Bragadeesh
Bragadeesh
BragadeeshV
Hello Junichi,
Bragadeesh
Bragadeesh
JuIn_1625121
Hello Bragadeesh,
Thank uou for your answer.
I understood these timing of MBR3 is the same as "Full Auto tune-Mode".
Is it correct?
Inoue
BragadeeshV
MBR3 allows you to set finger threshold manually if automatic thresholding is diabled. Hence, it does both things.
Bragadeesh
Bragadeesh
