I am using PSoC 4200M series (CY8C4247AZI-M485). I was trying to use the ADC. Just to get a feel for it, I uploaded the ADC_SAR_Seq_Die_Temp_PSoC4 example code in the PSoC creator 4.2 to check the measured voltage. When I ground the ADC pin the ADC does not read 0mV, instead it reads any value ranging from a few tens of mV to about 3-4V. However when I give it a voltage equal to the reference voltage (VDDA) it reads it properly. Can someone please guide me on what might be happening and how to fix it?
- adc_sar_seq
- psoc4200m
That is a nice example code!
I did not know about "DieTemp", so I gave it a try.
Since you are using CY8C4247AZI-M485, I imagined that you are using
either CY8CKIT-044 or CY8CKIT-043.
To go with these board, I modified the schematic so that we can use KitProg UART.
schematic
CY8CKIT-044
pin list
Tera Term log when I moved the pot
So the reading was from 0mV to 1024mV (actual VDD was 3.3V, with this)
Then I tried with CY8CKIT-043
pin list (schematic was same)
Tera Term log
So, with my usage, both CY8CKIT-044 and CY8CKIT-043 printed out 0mV ~ 1024mV.
FYI, modified main.c
* File Name: main.c
* Version: 2.10
* Description:
* Sequencing SAR ADC and DieTemp datasheet example project.
* Note:
* Pin_Vin pin (P0[4]) must be connected to the GND.
* UART_tx pin (P0[5]) must be connected to the pin (P12[6]) of J8 header.
* Verify that J9 is connected to 5V.
* Hardware Dependency:
* PSoC4 Pioneer kit
* Copyright 2013-2017, Cypress Semiconductor Corporation. All rights reserved.
* This software is owned by Cypress Semiconductor Corporation and is protected
* by and subject to worldwide patent and copyright laws and treaties.
* Therefore, you may use this software only as provided in the license agreement
* accompanying the software package from which you obtained this software.
* CYPRESS AND ITS SUPPLIERS MAKE NO WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
* WITH REGARD TO THIS SOFTWARE, INCLUDING, BUT NOT LIMITED TO, NONINFRINGEMENT,
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
#include <project.h>
#include <stdio.h>
/* ADC SAR sequencer component header to access Vref value */
#include <ADC_SAR_SEQ.h>
#define CH0_N (0x00u)
#define TEMP_CH (0x01u)
#define DELAY_1SEC (1000u)
/* Get actual Vref. value from ADC SAR sequencer */
#define ADC_VREF_VALUE_V ((float)ADC_SAR_SEQ_DEFAULT_VREF_MV_VALUE/1000.0)
volatile uint32 dataReady = 0u;
volatile int16 result[ADC_SAR_SEQ_TOTAL_CHANNELS_NUM];
volatile uint32 timer_delay = 0u;
char str[128] ; /* print buffer */
void print(char *str)
UART_UartPutString(str) ;
* Function Name: ISR_TIMER_LOC
* Summary:
* Handle Interrupt Service Routine. Source - TIMER.
CY_ISR(ISR_TIMER_LOC)
timer_delay++;
/* Measures temperature once per second */
if(timer_delay > DELAY_1SEC)
/* Enables injection channel for next scan */
ADC_SAR_SEQ_EnableInjection();
timer_delay = 0u;
/* Clears interrupt request from terminal count */
PWM_ClearInterrupt(PWM_INTR_MASK_TC);
* Function Name: ADC_SAR_SEQ_ISR_LOC
* Summary:
* Handle Interrupt Service Routine. Source - ADC SAR Seq.
CY_ISR(ADC_SAR_SEQ_ISR_LOC)
uint32 intr_status;
uint32 range_status;
/* Read interrupt status registers */
intr_status = ADC_SAR_SEQ_SAR_INTR_MASKED_REG;
/* Check for End of Scan interrupt */
if((intr_status & ADC_SAR_SEQ_EOS_MASK) != 0u)
/* Read range detect status */
range_status = ADC_SAR_SEQ_SAR_RANGE_INTR_MASKED_REG;
/* Verify that the conversion result met the condition Low_Limit <= Result < High_Limit */
if((range_status & (uint32)(1ul << CH0_N)) != 0u)
/* Read conversion result */
result[CH0_N] = ADC_SAR_SEQ_GetResult16(CH0_N);
/* Set PWM compare from channel0 */
PWM_WriteCompare(result[CH0_N]);
/* Clear range detect status */
ADC_SAR_SEQ_SAR_RANGE_INTR_REG = range_status;
dataReady |= ADC_SAR_SEQ_EOS_MASK;
/* Check for Injection End of Conversion */
if((intr_status & ADC_SAR_SEQ_INJ_EOC_MASK) != 0u)
result[TEMP_CH] = ADC_SAR_SEQ_GetResult16(TEMP_CH);
dataReady |= ADC_SAR_SEQ_INJ_EOC_MASK;
/* Clear handled interrupt */
ADC_SAR_SEQ_SAR_INTR_REG = intr_status;
* Function Name: main
* Summary:
* Parameters:
* None.
* Return:
* None.
int main()
int16 res = 0;
int32 temperature;
char uartLine[250];
int16 ADCCountsCorrected;
/* Initialize the UART */
UART_Start();
print("\r\n") ; // UART_PutCRLF();
// UART_PutString("Starting temperature measurement...");
print("Starting temperature measurement...");
PWM_Start();
PWM_TriggerCommand(PWM_MASK, PWM_CMD_START);
/* Init and start sequencing SAR ADC */
ADC_SAR_SEQ_Start();
ADC_SAR_SEQ_StartConvert();
/* Enable interrupt and set interrupt handler to local routine */
ADC_SAR_SEQ_IRQ_StartEx(ADC_SAR_SEQ_ISR_LOC);
/* Init interrupt from timer to measure the temperature rarely */
ISR_TIMER_StartEx(ISR_TIMER_LOC);
CyGlobalIntEnable;
for(;;)
/* When conversion of sequencing channels has completed */
if((dataReady & ADC_SAR_SEQ_EOS_MASK) != 0u)
/* Get voltage, measured by ADC */
dataReady &= ~ADC_SAR_SEQ_EOS_MASK;
res = ADC_SAR_SEQ_CountsTo_mVolts(CH0_N, result[CH0_N]);
/* When conversion of the injection channel has completed */
if((dataReady & ADC_SAR_SEQ_INJ_EOC_MASK) != 0u)
dataReady &= ~ADC_SAR_SEQ_INJ_EOC_MASK;
* Adjust data from ADC with respect to Vref value.
* This adjustment is to be done if Vref is set to any other than
* internal 1.024V.
* For more detailed description see Functional Description section
* of DieTemp P4 datasheet.
ADCCountsCorrected = (int16)(result[TEMP_CH]*(((float)ADC_VREF_VALUE_V/1.024)));
temperature = DieTemp_CountsTo_Celsius(ADCCountsCorrected);
/* Print temperature value to UART */
sprintf(
uartLine, "Temperature value: %dC",
(int16) temperature
print(uartLine) ; // UART_PutString(uartLine);
/* Print voltage value to UART */
sprintf(
uartLine, "ADC measured voltage: %dmV",
(uint16) res
/* [] END OF FILE */
moto
schematic
CY8CKIT-044
pin list
Tera Term log
* File Name: main.c
* Version: 2.10
* Description:
* Note:
* PSoC4 Pioneer kit
#include <stdio.h>
* Summary:
timer_delay++;
timer_delay = 0u;
* Summary:
uint32 intr_status;
* Summary:
* Parameters:
* None.
* Return:
* None.
int main()
int16 res = 0;
int32 temperature;
char uartLine[250];
UART_Start();
PWM_Start();
CyGlobalIntEnable;
for(;;)
* internal 1.024V.
sprintf(
(int16) temperature
sprintf(
(uint16) res
moto
Hey this is awesome! Thanks a lot for the quick reply. I am using CY8CKIT-043. I just tried your code with the pot. It's working fine. But looks like a sudden jump from 0-5V seems to have some settling time. Other than that I think I was having some loose connection. So I rigged up a GPCB and tried it with the pot. And it properly measure a 0 when grounded.
