Does Infineon have comparison table or tools to help compare package dimensions and trade-offs?
Ideally, the comparison information would be in a table to facilitate parametric search capabilities and list:
- Package type or name (e.g. BGA, TQFP, QFN...)
- Physical package body (e.g. 8.0 x 8.0 mm)
- Recommended space on PCB (including area for landing pads. Note that a 7x7mm 48-TQFP will take more PCB area than a 8x8mm 68 -QFN due to gull wing pins on the TQFP.)
- Number of Pins
- Process technology required to use the package (this may be due to pin separation or under package soldering...)
- Which Infineon devices are offered in each package
- Other technology comparisons or notes describing tradeoffs with technologies
Any links to similar web pages, applications notes, or selection criteria would be appreciated.
Greg
Community Information
This is not the best answer, but you can access all PKG information from the RUL below.
I hope this will be helpful to you.
