Other Technologies General
PascualJ_51
Is it possible to add a fixed DC offset voltage to the clock output?
If yes, which part of the JEDEC file should change?
I am using this PLL to have 24MHz+-2000ppm at the output.
PradiptaB_11
No it is not possible to add a fixed DC offset voltage to the clock output for this chip.
Pradipta.
PradiptaB_11
Pradipta.
PascualJ_51
Hi, can you give a sample solution?
Like have the output connected to a DC supply?
