Other Legacy MCU
Hello All,
In the Core Test of the STL, the interrupt sub-test for confirms that the function of each stage works correctly in the attached block diagram. This message can learn form former Case #00396744.(Also can refer to the figure).
Recently, TÜV Rheinland have a question. Please we consider the bit error whether or not will cause the unexpected interrupt ?
So I want know if the result of the Core Test is good, that can prove that don't occur bit error or unexpected interrupt ?
Best regards.
Guanghua Zhu.
Roy_Liu
STL relevant queries are not suitable to discuss in this community, recommendation is contacting your Cypress sale/support team directly.
Roy Liu
Roy_Liu
Roy Liu
OK, I have directly contacted Amy via email. Thanks your reply
