Nor Flash
huko_4668366
New Contributor
hi,
  We found in the s25fl512.v and s25fl256s.v define SPEEDSIM have the same define value with no-define SPEEDSIM.
And it takes so long time to run the simulation if the SPEEDSIM didn't work.
   The code is below.
    `ifdef SPEEDSIM
        // Page Program Operation
        specparam        tdevice_PP_256            = 55e7;//tPP
        specparam        tdevice_PP_512            = 75e7;//tPP
        // Typical Byte Programming Time
        specparam        tdevice_BP                = 4e8;//tBP
        // Sector Erase Operation
        specparam        tdevice_SE                = 1875e7;//tSE
        // Bulk Erase Operation
        specparam        tdevice_BE                = 460e9;//tBE
        // WRR Cycle Time
        specparam        tdevice_WRR               = 2e9;//tW
        // Erase Suspend/Erase Resume Time
        specparam        tdevice_ERSSUSP           = 40e6;//tESL
        // Program Suspend/Program Resume Time
        specparam        tdevice_PRGSUSP           = 40e6;//
        // VCC (min) to CS# Low
        specparam        tdevice_PU                = 3e8;//tPU
        // PPB Erase Time
        specparam        tdevice_PPBERASE          = 15e9;//
        // Password Unlock Time
        specparam        tdevice_PASSULCK          = 1e6;//
        // Password Unlock to Password Unlock Time
        specparam        tdevice_PASSACC           = 100e6;
    `else
        specparam        tdevice_SE                = 1875e9;//tSE
        specparam        tdevice_BE                = 460e12;//tBE
        // WRR Cycle Time
        specparam        tdevice_WRR               = 2e11;//tW
        // PPB Erase Time
    `endif // SPEEDSIM
   So we need the correct vaule to speed up our simulation, tks.
SudheeshK
We would like to get some more details about this issue.
1. What is the version of Verilog model (s25fl512.v) that you use in your simulations?
2. Are you using SDF file for simulation?
Thanks and Regards,
Sudheesh
huko_4668366
New Contributor
hi,
1. the version is v2.14
2. no, we don't use sdf
Tks.
SudheeshK
The latest version on the Verilog model for our device S25FL512S is 2.16. It is available at: https://www.cypress.com/verilog/s25fl512s-verilog .
  1. Could you please use this latest model for your simulation?
  2. Use SDF file for your simulations and check if the error goes away.
Thanks and Regards,
Sudheesh
huko_4668366
New Contributor
 We downloaded the latest model, and that is v2.16, but still have the same problem.
 SDF file seems won’t work, tks.
发送自 Windows 10 版邮件应用
发件人: SudheeshK_26
发送时间: 2020年3月23日 14:11
收件人: hu kongyang
主题: Re: - s25fl512.v SPEEDSIM didn't work, we need thecorrct value to speed up simulation CYPRESS DEVELOPER COMMUNITY
s25fl512.v SPEEDSIM didn't work, we need the corrct value to speed up simulation
reply from SudheeshK_26 in Nor Flash - View the full discussion
Thanks and Regards,
Sudheesh
Reply to this message by replying to this email, or go to the message on Cypress Developer Community Start a new discussion in Nor Flash by email or at Cypress Developer Community Following s25fl512.v SPEEDSIM didn't work, we need the corrct value to speed up simulation in these streams: Inbox This email was sent by Cypress Developer Community because you are a registered user.
You may unsubscribe instantly from Cypress Developer Community, or adjust email frequency in your email preferences
SudheeshK
Could you please let us know the error that you observe while using SDF file for simulation?
Thanks and Regards,
Sudheesh
