Hi
We are a relatively small company and designed in this part to a product less than 2 years ago as it was readily available from many sources. But just making new batch of boards ordered but we find its now obsolete.
Anyone suggest a direct drop-in alternative hardware and firmware wise just to buy us time until next build, either Cypress or alterntive maker,.
Many thanks
David
Hello David,
We recommend to use S25FL064L. Please refer the datasheet from the link given below :
http://www.cypress.com/file/316661/download
Krishna.
Hello David,
Krishna.
Hello David,
Please note that FL064L does not have the same package as S25FL208K0RMFI041.
S25FL208K0RMFI041.  is 150 mil SOC package where as  FL064L has 208 mil SOC only.
You can also go for FL116K. The FL1-K is also EOL’ed but the parts are still available in Digikey stock
https://www.digikey.com/product-detail/en/cypress-semiconductor-corp/S25FL116K0XMFI043/1274-1124-1-N...
Since you want to buy time until next build and if you do not need large batch, the FL116K can be an alternative.
Please refer the Migration application note from the  link given below to check command set compatibility :
http://www.cypress.com/file/192191/download
Krishna.
Hello Krishna
Thank you very much for your prompt replies.
We clearly need to look at this properly for longer term and the information you have provided will help.
I am based in the UK and at the moment I can easily source this part which looks like it will drop in and work physically and electrically for us and I have ordered samples for tomorrow. Could you just confirm it should also be a reasonable drop in replacement for S25FL208K0RMFI041?
The part I can get easily for this build is S25FL116K0XMFI041
​Thanks again for your advice and help
David
Hello David,
Yes you can use S25FL116K0XMFI041 it as replacement for S25FL208K0RMFI041 and follow the Migration application note provided in the previous interaction. Both are pin and functional compatible.
Please note that the part S25FL116K0XMFI041 is EOLed. Glad to hear that  you were able to get it easily.  In case if you could not get it you can buy S25FL116K0XMFA041 which is drop in for S25FL116KMFI041 part.
Product termination notice for the part S25FL116KMFI041 is given below :
http://www.cypress.com/documentation/product-termination-notice-ptn/ptn171202a?source=search&cat=qua...
Krishna.
Thanks very much Krishna
David
