Nor Flash
Is there flash driver support for S29GL064S70FHI020 on U-Boot 1.3.1 and Linux 2.6.23.1?
Hello Kevin,
GL064S devices implement CFI 1.3 so these device should run out-of-the-box under Linux and also under u-boot.
The required driver can be found in any Linux source tree under drivers/mtd/chips/cfi_cmdset_0002.c.
Krishna.
BushraH_91
Hello Kevin,
Thank you for contacting us. We are currently reviewing your inquiry and get back to you soon.
Happy Holidays!
Bushra
Hello Kevin,
Krishna.
Hi Krishna,
Thank you very much for your fast reply.
