[NOTE: I'm not kernel developer ]
Hi Recently we changed from Micron(pc28f256p33bfe i suppose) to Spansion S29GL256S10TF102 and nothing else is changed.
And as i'm not much aware of kernel/Driver part so i don't know what could be this.
Some details provided below incase you guys can help
FAILURE LOGS :
NetRefDAC calibration: 0xff,0xff, 0xffff
md5sum in eeprom (115429abe4d090c834c58f11555026c7) is incorrect
Unable to verify eeprom, setting model to 'ZFS'
Reading PCB info again
Last[0] is ffff
Last[1] is ffff
Last[2] is ffff
Last[2] is ffff, datum is 2705
Q. [What exactly is datum ?]
Some more information:
we're running old ppc board:
/dev # Uname -a
/dev # Linux 192.168.1.1 2.4.4 #256 Fri .... ppc unknown
What noticed is this file is from kernel version linux-2.4.33.1(but board shows 2.4.4 probably someone must have updated this driver).
Code:
[where i can see this log]
static int do_write_oneword(struct map_info *map, struct flchip *chip, unsigned long adr, __u32 datum, int fast)
unsigned long timeo = jiffies + HZ;
unsigned int Last[4];
unsigned long Count = 0;
struct cfi_private *cfi = map->fldrv_priv;
DECLARE_WAITQUEUE(wait, current);
if (Last[(Count - 1) % 4] != datum){
printk("Last[%ld] is %x, datum is %x\n",(Count - 1) % 4,Last[(Count - 1) % 4],datum);
cfi_send_gen_cmd(0xF0, 0, chip->start, map, cfi, cfi->device_type, NULL);
DISABLE_VPP(map);
ret = -EIO;
DISABLE_VPP(map);
chip->state = FL_READY;
wake_up(&chip->wq);
cfi_spin_unlock(chip->mutex);
return ret;
Please help incase anyone know anytime bout it
Thanks In Advance .. !!
Someone suggested me it be due "unlock by pass mode" stuff. but i'm not aware of it.
Cont ...
Q. Does this Spansion S29GL256S10TF102 supports this unlock bypass mode.
Q. Any kernel version support for this device Spansion S29GL256S10TF102; which i can try.
Q. What is this "unlock bypass mode" in some simple language which i can understand.
if you've any other advise that ican follow
Thanks Again..
Vipul
