Non Volatile RAM (F-RAM & NVSRAM)
WaCh_4680201
New Contributor
Dear Cypress team,
I wonder if there is any compatible driver for this device at the space of U-Boot,
and U-Boot is release of 2016.07 on ARM platform.
Walter
SudheeshK
Unfortunately, we do not have a u-boot driver for CY14B101Qx.
Command set of CY14B101Qx is compatible with SPI flash devices, so suggest you to modify the SPI flash driver to support our nvSRAM.
Thanks and Regards,
Sudheesh
SudheeshK
Thanks and Regards,
Sudheesh
