Could you provide AC Switching Characteristics of I2C standard mode (100KHz) of FM24V01A?
Datasheet shows the Fast mode plus(1MHz) and the Hs mode(3.4MHz) only.
I believe that it is same as I2C bus specification published by NXP.
Customer want to confirm some parameters which are defined as max value at the standard mode.
Naoaki Morimoto
Hi Naoaki-san,
Yes, you are correct the specs are same as I2C bus specification by NXP. I am attaching the user guide by NXP which has the specs defined in it. Kindly refer to it, and let us know if you have any further query.
https://www.nxp.com/docs/en/user-guide/UM10204.pdf
Thanks and Regards,
Pradipta.
Hi Naoaki-san,
Thanks and Regards,
Pradipta.
