- Email to a Friend
Is it possible to access the system parameter ( block 15 ) from the external MCU?
In my case, I want to change the protocol from MCE to User UART after uploading the parameter file in MCE mode through an external MCU.
Mathan
- Email to a Friend
Hi @MathanRaja,
Yes, You can read the system parameters.
Using the STM32 program the iMotion device with the new parameter file with InterfaceConf0bit[2:0] = 1 ( USER UART) for changing to USER UART mode.
Krupashankar
- Email to a Friend
Hi Krupashankar,
I have updated the system configuration in block 15 through stm32 using the device programming method.
Now I can change protocol mode from MCE to User UART. But,
How to change the protocol from User UART to MCE through stm32?
Mathan
- Email to a Friend
Hi @MathanRaja,
MCE UART can be accessed only for a short duration just after the boot-up process( If UART0 is configured as USER UART). Please try uploading a new parameter file with InterfaceConf0bit[2:0] = 111 ( MCE UART) immediately after booting iMOTION device.
Please follow the step mentioned in the document to switch UART mode using MCE Designer: Switch UART mode for iMotion devices - KBA235121
Please let us know if any further details are needed.
Krupashankar
- Email to a Friend
Hi Krupashankar,
I know this already, But I have already uploaded the parameter file through stm32 while in MCE mode. Once the upload is done. I have changed UART0 as User UART through stm32 by accessing page15. then I able to control the motor.
But now I want to change from User UART to MCE through stm32 if I use the same board for another motor that time i want to upload a specific motor parameter file.
so is it possible to change the protocol mode from user UART to MCE through an external MCU?
- Email to a Friend
Hi @MathanRaja,
Yes Please follow below method:
- Power off iMOTION completely
- Program the iMOTION device with new parameter InterfaceConf0bit[2:0] = 111 ( MCE UART) immediately after booting iMOTION device.
This helps to switch UART mode to MCE UART using STM32. MCE UART can be accessed only for a short duration just after the boot-up process( If UART0 is configured as USER UART).
Krupashankar
- Email to a Friend
Hi Krupashakar,
You meant to say, I have to start from the write parameter command on page 15 with MCE configuration.
am I correct?
- Email to a Friend
Do I have to follow device programming steps or something else?
without MCE mode how to do device programming?
- Email to a Friend
Hi @MathanRaja,
Yes, Please follow the device programming method. MCE UART will be accessible for a short time just after boot( Even though configured as USER UART). Please send Device programming commands just after boot to access MCE UART.
Krupashankar
- Email to a Friend
I have already tired. But there is no response.
How long it is in the boot?
