- Email to a Friend
How can I use duty cycle to control the speed for IMC30A? it seems that for IMC101T, there is a dedicated pin called "dutyfreq" to do this but IMC302A has no such pins. Is there a way to do this by scripting without using the MCU core or a Low pass filter? If so, could you please share a sample script for this application.
- Email to a Friend
Please use A-core to program and control the motor speed on IMC302A devices,
in-case it is intended to control the motor speed using external duty cycle input directly please use IMC101T device or similar T-core devices.
Best Regards
- Email to a Friend
Best Regards
