- Email to a Friend
I am working with the Infineon IMC101TF048XUMA1 motor controller for controlling a PMSM motor. I hope to put a limit on the PWM maximum duty cycle to any high-side PWM output (PWMUH, PWMVH, PWMWH) to avoid a overcurrent (GK) fault that occurs (apparently) when the PWM duty cycle approaches the limit (100%).
We are trying to solve a very serious issue. How can I limit the output to these PWM signals to keep the duty cycle to a limit? Is that possible with this controller?
Aaron
- PWM limit current
- Email to a Friend
Please ignore this request, since I believe I was heading down the wrong path. I still have a serious issue to solve as described in Fault-occurs-at-higher-speeds A run-away current condition occurs and I am looking for the reason.
Thanks, Aaron
- Email to a Friend
Thanks, Aaron
