Motor Control ICs Forum Discussions
MathanRaja
25 replies posted 5 questions asked 50 sign-ins
Hi ,
I am using stm32 for uploading the parameter file to eval board IMM101T-046M.
Now, I want to compare the parameter file in the chip with new parameter file stm32 going to upload. So that i can avoid reuploading the same parameter file.
Can you help me on this?
Mathan
Viswa
Moderator 10 replies posted 50 sign-ins First solution authored
Hi Mathan,
It is application dependent, please read the data of any known parameters from the iMOTION device like  Motor stator resistance or speed ramp rate etc, compare with known data points and take a decision whether to upload the new parameter file or not.
Viswa
Hi Mathan,
These is no such option to check the parameter file pre-programmed into the controller.
We suggest to read some parameters from iMotion and verify the data.
Please let us know if any further details are required.
Viswanadham Y
MathanRaja
Hi Viswanadham,
Can you tell what kind of parameter will help in comparing the file?
Mathan
Viswa
Hi Mathan,
