Motor Control ICs Forum Discussions
MathanRaja
25 replies posted 5 questions asked 50 sign-ins
Hi Support Team,
As you know, I am uploading the parameter file through stm32.
Now, If the power is off at the time of application mode (like connect, check communication, and change config mode to application mode). If I reconnect the board gets starts communicating.
But if the power is off at the time of Config mode. if I reconnect the board it is not communicating. So again I have to use MCE Designer to upload the parameter file. then, it starts communicating with stm32.
How to handle this? I want to upload the parameter file through stm32 after the power is off without MCE Designer's help.
Mathan
MathanRaja
I have resolved this issue.
In my, both eval board isolator chip was damaged. so I have removed that chip and shorted it.
while in that issue, I have given the same supply for both the onboard debugger and IMM chip.
now I have given a separate 3.3v supply for the debugger and IMM. The issue got resolved.
Mathan
Viswa
Moderator 10 replies posted 50 sign-ins First solution authored
Hi Mathan,
In this scenario,
try to establish communication with the iMOTION controller in SBSL mode, as we are in config mode the reply would be 0xCD.  The rest of the process will be same to get status and start uploading the data.
MathanRaja
Hi Viswa,
Is it possible to establish SBSL mode communication through stm32 without MCE software?
Viswa
Hi Mathan,
In the current scenario, we are trying to update the configuration parameters only(the MCE firmware is already programmed on the chip) .
On every power-up please check the reply for the connect command 0x00 0x6C,
if the return value is 0xCD it means the system is in Configuration mode and
we have to program the configuration parameters.
We can follow the process as outlined earlier to get the config status and update the config parameters.
Viswanadham Y
MathanRaja
Mathan
