Hello.
I try to use the TLE9185QXV33.
Do you have the driver library like the TLE9461(SBC)?
Thanks and Best regards.
Glenn.
Hi @GlJe_1688511,
Sorry for the inconvenience currently we do not have a C code for the above driver.
Thank you
Best Regards
Raj Chaudhari
Hi @GlJe_1688511,
You can download the Config Wizard for MOTIX motor gate driver IC from the Developer Center Launcher 2022 for configuring the TLE9185.
Thank you
Best Regards
Raj Chaudhari
Hi @GlJe_1688511,
For the user manual for the same, you can click on the help button in the upper right corner.
Please, let us know if you need further clarification.
Thank you
Best Regards
Raj Chaudhari
Hello Raj Chaudhari.
I found the sample code of TLE956x.
motor-system-ic-tle956x/docs at master · Infineon/motor-system-ic-tle956x · GitHub
I think that the sample code can be used to TLE9185 because the BLDC block are same.
Do you have the original code and the code with C code, not C++ code?
Glenn.
Hi @GlJe_1688511,
Thank you
Best Regards
Raj Chaudhari
