rg
First like received 5 sign-ins First reply posted
After reading through the thread named " Unable to install ModusToolbox", I cannot seem to figure out if the issue was resolved. Can you please comment on the outcome of that post? I am having the same issue.
Qi_Colin
50 likes received 100 solutions authored 5 questions asked
Hi @rg :
The thread of " Unable to install ModusToolbox" is solved.
I think you can check this issue following this thread at first.
Colin
lking
50 sign-ins 10 likes received 10 replies posted
Hi @rg
I read through the entire thread carefully, and like you I was confused as to what the solution was. I *think* the solution is: "ignoring the error message", but I am not sure. I didn't have this issue  while installing (or maybe I did and I simply ignored the error message), so I can't comment on your problem.
