How to use "Use Step Filters" and "Step into Selection"
Kenshow
Level 8
Level 8
Distributor - Marubun (Japan)
50 solutions authored 25 solutions authored 10 solutions authored
I have questions about items of run menu in ModusToolbox2.1 IDE.
Could you let me know how I use "Use Step Filters" and "Step into Selection" at debugging?
I am using PSoC6 CY8CKIT-062-BLE.
Kenshow
DheerajK_81
Yes, I was able to reproduce your issue. The features "Step into Selection", "Step filters" are all Java debugging options, but I expected it to be available for C/C++ as well. When I checked the Windows > Preferences > Debug options, there is no mention of Step Filtering method.
You can see these options available when you are debugging Java code on Native Eclipse.
So, in summary, I don't think these debugging options are supported. Even though the Debug perspective brings up those options, they aren't implemented and hence the error.
Hope this helps
Dheeraj
Len_CONSULTRON
Level 9
Level 9
Kenshow,
I did not find any info about "Step Filters" on the Cypress community Forums.
I did find this information on the internet about the Eclipse Step Filters:  Help - Eclipse Platform https://help.eclipse.org/2020-03/index.jsp?topic=%2Forg.eclipse.jdt.doc.user%2Freference%2Fviews%2Fd...
Maybe this can answer your question.
Len
Len
Kenshow
Level 8
Level 8
Hi Len,
Thank you for your reply. I will check tomorrow.
Kenshow
Kenshow
Level 8
Level 8
Hi all,
 I could not these step facilities.
 Can these debug step functions "Use step filter", "Step into selection", and "Drop To Frame" in eclipse be used in Modus Toolbox?
Kenshow
DheerajK_81
Hello Kenshow,
Note that these options are not available under Run tab in the ModusToolbox perspective. You will need to change to Eclipse Debug perspective by clicking this icon:
Once opened choose the Debug Perspective and then click Open.
Now you will be able to see the options in the Run tab.
Dheeraj
Kenshow
Level 8
Level 8
Hi Dheeraj,
The debug perspective highlights "Step Into Selection" only, not "Use step filter", and "Drop To Frame".
And, I met a problem when use "Step Into Selection" on debug perspective as follows:
Can these features that are often found in Java debugging be used in the C/C++ debugger?
Kenshow
DheerajK_81
Hope this helps
Dheeraj
Kenshow
Level 8
Level 8
Hi Dheeraj,
Thank you for your advice.
Kenshow
