If I create the custom BSP with "make bsp TARGET_GEN=MyCustomBSP DEVICE_GEN=CY8C4045AZI-S413", BSP is created with the following folder structure.
How can I create a BSP with the following folder structure?
Please tell me the operating procedure.
Yocchi
Hi Yocchi-san,
The CUSTOM_DESIGN_MODUS component needs to be created manually. Please refer to Section 5.4 Modifying the BSP Configuration for a Single Application (Page No - 51) in the ModusToolbox User Guide.
To use the custom BSP, please refer to Step 4: Use the new BSP in this KBA - ModusToolbox 2.2 and later: Make a Custom BSP - KBA231373
Rakshith M B
Hi Yocchi-san,
Rakshith M B
Hello Rakshith-san,
"Section 5.4 Modifying the BSP Configuration for a Single Application (Page No - 51)" is available to me.
Thank you very much.
Yocchi
