ModusToolbox General
WeGa_288606
New Contributor II
In PSoC Creator there is a "device selector" for changing the part number of a device. How is this achieved in ModusToolbox? I realize that I can select "Custom Hardware" on a new project but I am trying to figure out how to change a device if the project is existing.
Ekta
You can try recreating the project with the part number of the desired device.
Just replace the source file and design files of this project with source and design files of the previous project.
are you using a custom board or some psoc kit?
Best Regards
Ekta
Ekta
Best Regards
Ekta
WeGa_288606
New Contributor II
Hi Ekta,
We are using development kits as well as custom boards that we are developing. Part of our design and development workflow usually involves evaluating various parts or even migrating code from one part to another from previous projects.
Thank you for the help and support.
Wess
mattl_01
Unfortunately, this is not an easy way to do this in ModusToolbox 1.1 like you could with Creator.
We will facilitate this in ModusToolbox 2.0, but I'm not confident it will be as easy as it was in Creator.
I'll know more in a few months.
MaSt_1539621
New Contributor II
We are now at ModusToolbox v2.1.
Have there been any improvements to this process?
