ModusToolbox General
PhRi_4317641
New Contributor
I followed the directions followed here to locate the iOS example app: https://www.cypress.com/html_doc/AppNotes/AN227069/index.html#appendix-c-ios-helper-app-installation . I downloaded the appropriate ModulusToolbox_1.1 and then looked through the folder hierarchy and am only finding "Android" and "Windows" in peerapps folder. This directly contradicts the directions linked above since they claim that there is a folder named "iOS" in peerapps.
Any ideas on how I can find an example iOS app using Bluetooth Mesh?
Thank you for all the help.
DheerajPK_41
Please confirm whether you have successfully installed BTSDK1.4 or not, which is the latest BTSDK compatible for MTB-1.1. Otherwise please install it  ModusToolbox BT SDK 1.4 If you have installed proper BTSDK then you will see 4 peerapps as shown below.
Please note: The latest version of Modustoolbox is MTB2.0 and BTSDK is v2.1. Please check https://www.cypress.com/products/modustoolbox-software-environment
-Dheeraj
DheerajPK_41
-Dheeraj
