Serial Monitor doesn't work in Mbed Studio
PaYe_4603801
Level 4
Level 4
5 likes given Welcome! 25 replies posted
Following Alan Haws webinar featuring CY8CPROTO-062-4343W, I discovered that Serial Monitor doesn't work (i.e. no any output) on exactly same examples.
Here is one of webinar projects, where there is no output to Serial on my setup:
https://iotexpert.com/2019/12/09/mouser-psoc-6-wifi-bt-mbed-l4-temperature-thread/
The only difference - Alan worked on MacOS, me - on Windows.
Probably there is some bug on windows version of Mbed Studio ?
Today it works.
Probably it was some Windows problem preventing COM port to communicate.
DheerajK_81
Please check if you see your target is being shown in the Target option. Check if you are in KitProg3 DAPLink mode. What is the version of Mbed Studio you are working with? Not sure if that is the reason, but I am working on Mbed Studio 0.8.1 release on Windows 10 and I see the output as shown below:
Please double check if you followed all the steps in the blog. It works for me.
Dheeraj
Target: Ok
Programming mode: KitProg3 DAPLink mode (otherwise programming doesn't work at all)
Mbed Studio version: 0.9.0
Checking steps: checked
Here is output:
Today it works.
