MOSFET (Si/SiC) Forum Discussions
Jeff_Huang
5 questions asked Welcome! First question asked
Hi,Sir,
About minimum dead time setting, I already know the calculation and setting method of IGBT device.
For minimum dead time  of SiC device,are there any differences and matters needing special attention compared with IGBT? Do you have a more detailed description, such as providing a document to introduce it? Thank you for your support.
BR,
Jeff Huang
Guru_Prasad
Moderator 100 replies posted First question asked 10 likes received
Hello @Jeff_Huang
Thanks for posting the question in the Infineon community.
The SiC half-bridge dead-band time setting process is the same as the IGBT half-bridge dead band. Since SiC
devices are high frequency devices the time value  would be lower for Sic devices compared to IGBT device.
Guru_Prasad
Guru_Prasad
Hello @Jeff_Huang
Guru_Prasad
