leo_dc
First like given 5 sign-ins First reply posted
Evaluation board REF_62W_FLY_1700V_SIC of 1700 V CoolSiC MOSFET doesn't have gerber files in PCB Design Data. Can you please provide the gerber files of the board?
AZIZ_HASSAN
50 likes received 5 likes given 250 sign-ins
Thank you for posting your query at Infineon community.
Please refer to the link attached, there in PCB design data, you will get Altium designer file.Please downloadf the file and same you can convert to gerber. Once you convert the file to gerber, you can even make changes in gerber as per your requirement as well.
https://www.infineon.com/cms/en/product/evaluation-boards/ref_62w_fly_1700v_sic/
BR,
AZIZ HASSAN
AZIZ_HASSAN
BR,
AZIZ HASSAN
Hi Aziz, Thanks. I assume it would require Altium license. If possible provide the gerber files, otherwise I will do what you have suggested.
AZIZ_HASSAN
I request you to do the same as I suggested because by doing so, you can even make changes in gerber as per your requirement.
BR,
AZIZ HASSAN
I hope you converted the file to gerber.
BR,
AZIZ HASSAN
leo_dc
Yes.
