Hello, I hope you are doing well.
I am writing you because I need a piece of advice regarding the availability of a component and if you have an idea about alternatives.
I am using the following reference IPB042N10N3 G of MOSFET from Infineon (Please check the following link => Infineon-IPB042N10N3 G-DS-v02_09-EN.pdf). I just knows that this reference is becoming obsolete (I am talking about big quantities for production) and I am looking for alternatives. By the same occasion, I would like to check with you, according to your experience, if the supplier can be involved to guarantee the quantity required. If so, what are the procedures to follow? If not, do you have in mind some references that can help me to replace this reference.
Looking forward to hearing from you soon.
Kind regards and thanks in advance.
Hassna
ispn:4403:1:0
l1:144:1:0
l2:152:1:0
l3:1341:1:0
Hello @hassna ,
Thank you for posting on Infineon.
Below are some of the alternates that you can consider for IPB042N10N3 G.
Product | Product Status | Standard Package name | Infineon Package name | VDS max [V] | RDS (on) @10V max [mΩ] | QG typ @10V [nC] | QG typ @4.5V [nC] | VGS(th) [V] | ID @25°C max [A] | Technology | Qualification | Operating Temperature min [°C] | Operating Temperature max [°C] | |
Reference | IPB042N10N3 G | active | D2PAK | PG-TO263-3 | 100 | 4.2 | 88 | 2.7 | 137 | OptiMOS™ 3 | Industrial | -55 | 175 | |
Alternates | IRFS4010 | active and preferred | D2PAK | D2PAK | 100 | 4.7 | 143 | 3 | 180 | IR MOSFET™ | Standard | -55 | 175 | |
IPB027N10N5 | active and preferred | D2PAK | PG-TO263-3 | 100 | 2.7 | 112 | 3 | 166 | OptiMOS™ 5 | Industrial | -55 | 175 | ||
IPB020N10N5 | active and preferred | D2PAK | PG-TO263-3 | 100 | 2 | 168 | 3 | 176 | OptiMOS™ 5 | Industrial | -55 | 175 | ||
IRLS4030 | active and preferred | D2PAK | D2PAK | 100 | 4.3 | 87 | 1.75 | 180 | IR MOSFET™ | Standard | -55 | 175 | ||
IRF100S201 | active and preferred | D2PAK | D2PAK | 100 | 4.2 | 170 | 3 | 192 | IR MOSFET™ | Standard | -55 | 175 |
Please contact the nearest Infineon Sales office for supply related topics.
https://www.infineon.com/cms/en/about-infineon/company/find-a-location/
Meghana R
Vds 100V
Rds 4.2mOhm
Id 137A
Vgs 20V
Ptot 214 W
Tr 59 ns
Alternatives: IPB042N10N3G; IPB039N10N3G; AOB292L; SM1A00NSG
Hello Gigio,
Thanks for your feedback.
I really appreciate it.
Kind regards.
Hello @hassna ,
Meghana R
