General Information regarding Transistors
PowerStarter_
10 questions asked First solution authored 10 likes given
is there any source, where a table can be found, which contains the switching-frequency of the following Transistors?
GaN, SiC, Si, IGBT, ...
I was only able to find diagrams. E.g.:
vigneshkumar
25 likes received 250 sign-ins 50 solutions authored
Hi ,
Please refer Page 213 for IGBT  frequency detail in the below link. currently we don't have detailed table  with frequency and power  for all types but we have selection guides for Si, SiC, GaN,IGBT. Based on your application you can select device or we can help you to find a suitable device
https://www.infineon.com/dgdl/Infineon-Power_and_Sensing-ProductSelectionGuide-v00_01-EN.pdf?fileId=...
Thanks & Regards,
Vignesh kumar
Arpit_S
50 likes received 250 replies posted 100 solutions authored
Thanks for those links. Unfortunately, they don't offer tables with general frequencies and power-levels. At least I haven't seen them.
Best Regards
vigneshkumar
Hi ,
Thanks & Regards,
Vignesh kumar
