Dear Sir,
How to evaluate power device junction temperature, at the time of Eon?
For example, the power dissipation I see is about 6kW+2.3kW,
Is my temperature rise equal to TA + (6kW+2.3kW) *RJA?
Hello Kuowenyung,
Temperature rise has to be estimated based on the average losses and not considering the peak dissipation.
You may estimate the average loss during turn-on as below, by approximating the power curve as a triangle.
Psw_on = (1/2 * ton * Vds*Id)/T
where T - total switching period
Here 6kW would account for Vds*Id.
Temperature rise due to the turn-on losses can be calculated as below
Tj= Psw_on * Rthj-a + Ta
But you may not be able to observe this change in real-time as temperature rise will be gradual and not instantaneous.
Hence to estimate the actual junction temperature of your device, it is advised to estimate the total power loss over a switching period, which will include both conduction and switching losses and then calculate the junction temperature as below.
Tj= Ploss*Rthj-a + Ta
where Ploss = Pcond + Psw
I hope this helps. Please feel free to reach out to us if you need further clarification on this topic.
Meghana R
Hello Kuowenyung,
Meghana R
