MADK
User22872
New Contributor
In PFC stage of EV charger. How to calculate the maximum PI output value for pi voltage controller if the required power limit is 3.4kW. This value is used in duty cycle calculation for mosfet gate signal
Krupashankar
Hi Rakesh,
Could you please tell us What is battery bus voltage and maximum current rating?
and please share the details of MCU and power board and SDK version.
Krupashankar
Rakesh_rp
New Contributor
hi krupashankar,
This is rakesh . replying you from a new myinfineon account.
I am using  xmc1300 (xmc1302 -T038x0200 )development board for PFC stage in 3.4kW onboard EV charger. The max dc bus voltage at LLC stage is 64v and the  max current rating is 53A.  How to scale this 3.4kW power limit , so that I can use it in the software calculations. I am using DAVE 4.4.2 VERSION.
Top labels
