moro_1580446
100 replies posted 50 replies posted 25 replies posted
Hi everybody.I want to read wave sound from SDCARD and put out with wavevdac8 and connect speaker.
1-My first question is that possible?
2-Secound question i dont know how can i set wavedac refrence read from sd card?
Thanks for attention...
himam_31
Hello
The data rate depends on the wav file . Can you please check the document.The sampling frequency rates are mentioned.Can you please try using the same data rate for the DAC.
Hima
moro_1580446
I can reading text file from sdcard and i can run wavedac component.so i my problem is how can i connect both component together...
moro_1580446
I can to change wav sound to char array and put out by wavedac8 and amply with lm386 to hear best quality.so my question is what is good sample rate to play wave sound ?i cant hear sound obvious...
my project attached so if there anybody to find good sample rate setting?
please help me...
moro_1580446
nobody can help me?
I dont know what is correct KSPS for wavedac8 to good hearing sound?
himam_31
Hello
Hima
