Writing Flash Memory in FR Family FR81S MCUs - KBA218673
11:39 PM
- Mark as Read
- Printer Friendly Page
Mar 23, 2017
11:39 PM
Version: **
Translation - Japanese: FRファミリFR81S MCUのFlashメモリへの書込み — KBA218673 - Community Translated (JA)
Question:
How do you write flash memory in the FR81S MCUs?
Answer:
The FR Family FR81S MCUs can be programmed with two serial writers; CAN MCUs can be programmed with one serial writer.
- Programming with Flash serial writer using SIO
- Programming with PC serial writer using UART
Notes:- The frequency of the crystal oscillator that can be specified for each type of microcontroller is limited.
- For information on microcontrollers compatible with the PC serial writer, contact Cypress Technical Support.
- Programming with Flash serial writer via CAN
When programming with a serial writer (such as Yokogawa Digital Computer Corporation (YDC) products) via CAN to Flash MCU, a boot program (from YDC) needs to be programmed to the Flash MCU; this is also possible using CAN.
Labels
- fr81s family
Rate this article:
Contributors
This widget could not be displayed.Anonymous
