Knowledge Base Articles
Using a PRS Generator as a PWM - KBA83077
pushekm_21
Version: **
Question: How do I use a Pseudo Random Sequence (PRS) generator as a Pulse Width Modulator (PWM) in PSoC® Designer?
Answer:
Answer : The PRS generator uses a Linear Feedback Shift Register (LFSR) to generate a pseudo-random bit stream. You can configure the PRS to output the LSB of the bit stream in order to implement a PRS PWM. Using a PRS PWM spreads the signal energy over the complete spectrum and significantly lowers EMI.
The PRS Pulse Width Modulator example project demonstrates how to implement a PRS PWM. It also compares the frequency spectrum of a PRS PWM with a conventional PWM.
PRS Pulse Width Modulator Project Documentation
PRS Pulse Width Modulator PSoC Project Files
Version history
Revision #:
1 of 1
Last update:
‎Mar 23, 2012 07:58 AM
Updated by:
Contributors
