Knowledge Base Articles
Using UART in PSoC1
pushekm_21
Using UART in PSoC1
Question: How to implement a UART in PSoC1?
Answer:
For the implementation of UART, two communication digital blocks are required. PSoC Designer provides an 8-bit UART UM with a set of APIs for data communication.
Attached document and project provides an example of how to configure UART for a particular baud rate. It also shows how to handle the transmission and reception of data via UART on both PC and device side.
Version history
Revision #:
1 of 1
Last update:
‎Jan 25, 2012 12:00 AM
Updated by:
Contributors
