Knowledge Base Articles
Unable to clone project created in old PSoC Designer version (earlier than PD4.4) to PSoC Designer 5.1
Question: When I try to clone a project created in PD4.1 to PD5.1 I get "CMX MFC Application Error" and project fails to clone. What is the reason and what is the workaround?
Answer:
The problem is that PSoC Designer 5.1 doesn't support projects created on PSoC Designer version earlier than 4.4. Steps for how to clone old projects to PD5.1 are below:
1. Open your project in PD4.1 (or whichever PD version the project was originally built in), and rebuild
2. Open your rebuilt project in PD5.1
3. Unplace all UMs and build. There will be errors, please ignore them. Close project.
4. Create a new PD5.1 project. Choose a name and select "Clone project". Select the Project which was created after step 3.
5. Choose Target device and hit OK.
6. PSoC Designer 5.1 will delete all unsupported User Modules. You must then place all necessary UMs manually.
Version history
Revision #:
1 of 1
Last update:
‎Oct 19, 2011 06:43 PM
Updated by:
Contributors
