USB to Parallel Converter Using FX2LP
11:40 PM
- Mark as Read
- Printer Friendly Page
Mar 08, 2011
11:40 PM
How to use FX2LP to make USB to parallel converter?
The data received over the USB should be made available on a parallel data bus on the GPIO pins.
- There are two methods to implement a USB to Parallel interface in FX2LP.
The GPIF or Slave FIFO mode of FX2LP can be used depending on the external device which is being interfaced with FX2LP.
Without using the GPIF or Slave FIFO interface, firmware can be written to implement the same using the 8051 core.
Translation - Japanese: FX2LPを使用したUSB-パラレルコンバーター - Community Translated (JA)
Rate this article:
