Knowledge Base Articles
To read the RSSI value
Question: How to read RSSI value ?
Answer:
In order to read the value
Add the following line after the radio is initialised. RadioGetRssi() API returns the value of RSSI.
// Insert below code
BYTE rssi;
rssi =  RadioGetRssi();  //get rssi
Display the contents on an LCD. Please find the attached code example which does the same (Look for the above lines in main.c ).
Version history
Revision #:
1 of 1
Last update:
‎Apr 05, 2011 11:19 AM
Updated by:
Contributors
