Title: PSoC Designer 5.0 and LVPrcSrv issue.
12:00 AM
- Mark as Read
- Printer Friendly Page
Dec 29, 2011
12:00 AM
Question: System always hangs during the generate/build process in PSoC Designer 5.0. The system has a Webcam effects service from Logitech called "LVPrcSrv". If this service is stopped, PD5.0 works fine. If it is restarted, PD5.0 hangs.
Answer:
According to one Logitech user's forum, this is a known problem with the LVPrcSrv software. This is not an issue with PD5.0. Since the LVPrcSrv software doesn't affect normal operation of the Webcam, the workaround is to set the service to manual. This way it will not conflict with PD5.0.
Labels
- psoca software
Rate this article:
Contributors
This widget could not be displayed.Anonymous
