Recommended Reflow for Cypress Parts Information
Question: What is Cypress’s Parts Recommended Reflow?
Answer:
Please see below Cypress Reflow Profile. Cypress’s Reflow Profile is compliant with Jedec J-STD-020D.1.
Example on how to get the Peak package body temperature is shown below.
Reflow Profiles (per Jedec J-STD-020D.1)
     Profile Feature
     Sn-Pb Eutectic Assembly
     Pb-Free Assembly
     Preheat/Soak
     Temperature Min (Tsmin)
     100 °C
     150 °C
     Temperature Max (Tsmax)
     150 °C
     200 °C
     Time (ts) from (Tsmin to Tsmax)
     60-120 seconds
     60-120 seconds
     Ramp-up rate (TL to Tp)
     3 °C/second max.
     3 °C/second max.
     Liquidous temperature (TL)
     183 °C
     217 °C
     Time (tL) maintained above TL
     60-150 seconds
     60-150 seconds
     Peak package body temperature (Tp)
     For users Tp must not exceed the Classification temp in Table 2A. For suppliers Tp must equal or exceed the Classification temp in Table 2A
     For users Tp must not exceed the Classification temp in Table 2B. For suppliers Tp must equal or exceed the Classification temp in Table 2B
     Time (tp)* within 5 °C of the specified classification temperature (Tc), see Table 2a & 2B
     20* seconds
     30* seconds
     Figure 5-1. J-STD-020D.1
     Ramp-down rate (Tp to TL)
     6 °C/second max.
     6 °C/second max.
     Time 25 °C to peak temperature
     6 minutes max.
     8 minutes max.
     * Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum
Table 2A
SnPb Eutectic Process - Classification Temperatures (Tc)
     Package Thickness
               Volume  mm3
     <350
                    Volume mm3
     >=350
     <2.5 mm
     235 °C
     220 °C
     >=2.5 mm
     220 °C
     220 °C
Table 2B
Pb-Free Process -Classification Temperatures (Tc)
     Package Thickness
          Volume mm3
     <350
            Volume mm3
     350 - 2000
           Volume mm3
                  >2000
     <1.6 mm
     260 °C
     260 °C
      260 °C
     1.6 mm - 2.5 mm
     260 °C
     250 °C
     245 °C
     >2.5 mm
     250 °C
     245 °C
     245 °C
Note:
    1.   Peak Temperature tolerance is +5/-0 °C of Classification Temp (Tc).
    2.   All temperatures refer to topside of the package, measured on the package body surface.
    3.   Package volume excludes external terminals (e.g., balls, bumps, lands, leads) and/or nonintegral heat sinks.
     For example:
    To be able to get the reflow profile of a part, we need to know first the Package dimension or volume.
    MPN: CY7C65620-56LTXC
    Package: QFN56, Pb-Free Part
    Package Dimension: 8x8x1.0mm
    Package Volume: 64mm3
    Package Thickness: 1.0mm
    You can get package dimension on the datasheet’s Package Diagram.
    Since the part is a Pb Free Part, Table 2B should be used. Based on this table, is the package volume is <350 mm3 and the package thickness is <1.6mm, Peak Temperature = 260 °C
    If the part number is SnPb Part, Table 2a is applicable.
    Contributors
